BLOCK IP RANGE.....NATION.
BoostOver
Good evening everyone.
I would need to block the IPs of an entire nation.
I found this service:
My question is the following,
Which add-on should I use to use the IP2LOCATION service?
It's possible?
Which file should I use to download from IP2LOCATION?
It's possible?
Why not use Skynet? It's already built-in.
Thanks, i'm noob :-(
Could you explain to me how to block an entire nation?
You are able to add country code in addition to standard or custom block lists. Install Skynet via amtm, and it's fairly intuitive.
Thanks for all.
I have one last question.
I want to designate a single IP on my network...how can I do it?
Thanks for all.
Not sure what you're asking.
I don't think that is possible with Skynet.
