Block only one IP address
Joergi
Hello forum,
I have an AV-Receiver with web interface (192.168.2.22).
I can't disable or protect the web interface in the Receiver.
Is there an opportunity to block the IP address in the AC87U router (380.58),
that I can’t open the web interface.
I tried it with the firewall network services filter, but did not work.
Don't use 'TCP ALL'...just use 'TCP'. TCP ALL isn't what the name would imply and is actually a pretty useless option (I've removed it in my fork).
Hello john9527,
I try it, but it's the same.
I can open the web interface.
You can't firewall LAN traffic between two devices, since that traffic is switched, not routed. It never reaches the firewall.
Merlin just beat me with the answer....I must be sleepy this AM.....
The Network Services filter is for blocking traffic going from your LAN to the WAN.
No chance to block, like the web interface of the router (Web Interface -> Specified IP address (Max Limit : 4))?
No, no chance sorry. That function has to be provided by the receiver..
I don't know what brand receiver you have, but my Yamaha has a 'mac filter' function for access to the receiver (although I've never used it).
Info:
I changed the connection of the receiver to WLAN (receiver has both LAN/WLAN).
I created a new Guest Network for the receiver.
Now I can enable/disable the access to the web interface via Access Intranet.
