Block samba for client using iptables?
enrysan0
I just want to block access to samba service on the router to a client with a given ip address.
I tried this, but it's not working:
iptables -I INPUT -s ipaddress -p udp --dport 445 -j DROP
iptables -I INPUT -s ipaddress —p udp --dport 137 -j DROP
iptables -I INPUT -s ipaddress -p udp --dport 138 -j DROP
iptables -I INPUT -s ipaddress -p udp --dport 139 -j DROP
iptables -I INPUT -s ipaddress -p tcp --dport 445 -j DROP
iptables -I INPUT -s ipaddress —p tcp --dport 137 -j DROP
iptables -I INPUT -s ipaddress -p tcp --dport 138 -j DROP
iptables -I INPUT -s ipaddress -p tcp --dport 139 -j DROP
iptables -I OUTPUT -d ipaddress -p udp --dport 445 -j DROP
iptables -I OUTPUT -d ipaddress —p udp --dport 137 -j DROP
iptables -I OUTPUT -d ipaddress -p udp --dport 138 -j DROP
iptables -I OUTPUT -d ipaddress -p udp --dport 139 -j DROP
iptables -I OUTPUT -d ipaddress -p tcp --dport 445 -j DROP
iptables -I OUTPUT -d ipaddress —p tcp --dport 137 -j DROP
iptables -I OUTPUT -d ipaddress -p tcp --dport 138 -j DROP
iptables -I OUTPUT -d ipaddress -p tcp --dport 139 -j DROP
any suggestions? thanks
I followed your suggestion and put this line in /jffs/configs/smb.conf.add
hosts deny = ipaddress
where ipaddress is the ip to block in the form xxx.xxx.xxx.xxx
restarted the samba service
(do you know how to restart smb by command line in ssh?)
the line is correctly appended to the auto generated smb.con file
but same like with te iptables command the client can connect/browse/open file in the samba shares.
The only thing both iptables commands and the modded smb.conf obtain is to make non discoverable the samba share on scan. But if the client was already configured to access to samba, it however can connect.
I don't know what's is wrong
Here is my iptables rules:
-P INPUT ACCEPT
-P FORWARD DROP
-P OUTPUT ACCEPT
-N FUPNP
-N PControls
-N dropkids
-N logaccept
-N logdrop
-A INPUT -p tcp -m tcp --dport 443 -j ACCEPT
-A INPUT -m set --match-set BlockedCountries src -j DROP
-A INPUT -m set --match-set TorNodes src -j DROP
-A INPUT -i tun21 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 1194 -j ACCEPT
-A INPUT -i tun11 -j ACCEPT
-A INPUT -m state --state INVALID -j DROP
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i lo -m state --state NEW -j ACCEPT
-A INPUT -i br0 -m state --state NEW -j ACCEPT
-A INPUT -p udp -m udp --sport 67 --dport 68 -j ACCEPT
-A INPUT -j DROP
-A FORWARD -s 192.168.150.102/32 -i br0 -o eth0 -j DROP
-A FORWARD -s 192.168.150.135/32 -i br0 -o eth0 -j DROP
-A FORWARD -s 192.168.150.115/32 -i br0 -o eth0 -j DROP
-A FORWARD -m time --timestart 00:00:00 --timestop 05:00:00 --weekdays Sun -j dropkids
-A FORWARD -m time --timestart 23:00:00 --timestop 23:59:59 --weekdays Sun -j dropkids
-A FORWARD -m time --timestart 00:00:00 --timestop 05:00:00 --weekdays Mon,Tue,Wed,Thu,Fri,Sat -j dropkids
-A FORWARD -m time --timestart 23:30:00 --timestop 23:59:59 --weekdays Mon,Tue,Wed,Thu,Fri,Sat -j dropkids
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i tun21 -j ACCEPT
-A FORWARD -i tun11 -j ACCEPT
-A FORWARD ! -i br0 -o eth0 -j DROP
-A FORWARD -m state --state INVALID -j DROP
-A FORWARD -i br0 -o br0 -j ACCEPT
-A FORWARD -i eth0 -p icmp -j DROP
-A FORWARD -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 1/sec -j ACCEPT
-A FORWARD -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec -j ACCEPT
-A FORWARD -i eth0 -p icmp -m icmp --icmp-type 8 -m limit --limit 1/sec -j ACCEPT
-A FORWARD -m conntrack --ctstate DNAT -j ACCEPT
-A FORWARD -i br0 -j ACCEPT
-A FUPNP -d 192.168.150.135/32 -p udp -m udp --dport 51547 -j ACCEPT
-A PControls -j ACCEPT
-A dropkids -d 192.168.1.108/32 -j DROP
-A dropkids -s 192.168.1.108/32 -j DROP
-A dropkids -d 192.168.1.104/32 -j DROP
-A dropkids -s 192.168.1.104/32 -j DROP
-A dropkids -m mac --mac-source [B]AA:BB:CC:DD:EE:FF[/B] -j DROP
-A logaccept -m state --state NEW -j LOG --log-prefix "ACCEPT " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logaccept -j ACCEPT
-A logdrop -m state --state NEW -j LOG --log-prefix "DROP " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop -j DROP
NAT:
-P PREROUTING ACCEPT
-P INPUT ACCEPT
-P OUTPUT ACCEPT
-P POSTROUTING ACCEPT
-N DNSFILTER
-N LOCALSRV
-N VSERVER
-N VUPNP
-A PREROUTING -p tcp -m tcp --dport 1194 -j ACCEPT
-A PREROUTING -d 192.168.1.64/32 -j VSERVER
-A PREROUTING -s 192.168.150.0/24 -p udp -m udp --dport 53 -j DNSFILTER
-A PREROUTING -s 192.168.150.0/24 -p tcp -m tcp --dport 53 -j DNSFILTER
-A POSTROUTING -s 192.168.150.0/24 -o tun11 -j MASQUERADE
-A POSTROUTING ! -s 192.168.1.64/32 -o eth0 -j MASQUERADE
-A POSTROUTING -s 192.168.150.0/24 -d 192.168.150.0/24 -o br0 -j MASQUERADE
-A DNSFILTER -m mac --mac-source [B]AA:BB:CC:DD:EE:FF[/B] -j DNAT --to-destination [B]xxx.xxx.xxx.xxx[/B]
-A DNSFILTER -m mac --mac-source [B]AA:BB:CC:DD:EE:FF[/B] -j DNAT --to-destination 192.168.150.1
-A DNSFILTER -m mac --mac-source [B]AA:BB:CC:DD:EE:FF[/B] -j DNAT --to-destination 208.67.222.222
-A DNSFILTER -j DNAT --to-destination 192.168.150.1
-A VSERVER -j VUPNP
Mangle (used for selecting routing to the VPN):
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-A PREROUTING -i br0 -m iprange --src-range 192.168.150.102-192.168.150.102 -j MARK --set-xmark 0xa/0xffffffff
-A PREROUTING -i br0 -m iprange --src-range 192.168.150.135-192.168.150.135 -j MARK --set-xmark 0xa/0xffffffff
-A PREROUTING -i br0 -m iprange --src-range 192.168.150.115-192.168.150.115 -j MARK --set-xmark 0xa/0xffffffff
-A FORWARD -s 192.168.150.0/24 -d 192.168.150.0/24 -o br0 -m state --state NEW -j MARK --set-xmark 0x1/0x7
-A FORWARD -p udp -m state --state NEW -j MARK --set-xmark 0x1/0x7
Thanks and merry christmas!
