Blocking hardcoded dns to specific dns address
Swistheater
Okay, so I know how dnsfilter works, but I simply want to only block outbound dns for a specific device. It uses 1.1.1.1 for dns connections. I am attempting to prevent the device from dialing home. What are some user suggestions?
Block it instead of redirect it? How about dnsfilter to a bad IP? :)
Are you still talking about DNS servers or something else?
DNS blocking techniques on merlin
This is my first thought:
iptables -A INPUT -s Device-ip -p tcp –destination-port 53 -j DROP
iptables -A INPUT -s device-ip -p udp –destination-port 53 -j DROP
Why not just block all internet access for the device in question rather than creating some convoluted DNS blocking. I still don't know what your IPv6 comment was regarding.
Really my goal is just to prevent the device from making phoning home. Would you use network service filter for this? And it wasn't convoluted. It was merely asking if I did as dave suggested and used dns filter to redirect the traffic to a dummy ip, how would I do the same for ipv6 since the dnsfilter only incompass ipv4 traffic.
Maybe use Skynet IoT blocking?
Do you have an IPv6 internet service? If not then just block it using the option in the Client Status list.
Another alternative I've used for devices that need access to the Internet, but that I still want to prevent phoning home, is to see where they connect when phoning home and then block the entire IP block for that device. For example, if I want to block my Roku from phoning home I just enter something like:
iptables -A OUTPUT -s 192.168.1.2 -d 34.192.0.0/10 -j DROP
I believe you would have to use the FORWARD chain not the OUTPUT chain. It would also have to be inserted (-I) rather than appended (-A).
