Blocking ICMP on WAN
delid4ve
Numerous guides regarding firewalls state to block ICMP on the WAN interface (Input).
However, when i do this internet connection fails.
Now my ISP uses a /31 for the point to point connection (FTTP) to us, to which i then have 1x /30 and 1x /28 route-able blocks.
so my connection is:
0.0.0.0/0 dst - xx.xx.xx.70 gateway on ether1 - no pref source
xx.xx.xx.70 dst - gateway ether1 - xx.xx.xx.71 pref source
then my ip blocks on other interfaces feeding other routers which are NATed
From what i can see from logging the traffic is mainly:
input - icmp - type 8 code 0 from xx.xx.xx.70 to xx.xx.xx.71 accross the P2P link
Can anyone shed some light on this please?
Might want to clarify more about what your intent (or question) is...
Allowing ICMP on the WAN interface does no harm - and with ipv6, it helps...
