Ted Danson
I have two Netvue WiFi 1080p Home Cam IP cameras I would like to add to my network. They are being placed in bedrooms so for privacy and security reasons I have the following requirements:
https://www.snbforums.com/threads/how-to-block-ip-camera-from-accessing-the-internet.29693
The main thing is I don't want folk using Shodan (purely as an example) and what have you and trying to access these cameras due to some backdoor in them.
Thanks a million all.
- No access to the Internet at all except if I run a VPN server in order to connect home and access the cameras on the LAN.
- I have a Netgear GS716T smart switch attached to a port on my ASUS RT-AC5300 so would like to create a separate VLAN just for IOT devices. This is probably straying off topic but it's just when I've created VLAN's on the switch before I lose access to the devices put in that VLAN. I'm assuming I need to set up the trunk port or something on the switch pointing to the router but I'm not too clued up for it. If I can do this then I'd like to separate my IOT devices too at a later stage so learning this would be a bonus.
- I'd like to ensure that the cameras can pickup NTP transmissions so a flat out parental filter block won't really do.
- With regards VLAN's can I segment 2.4 and 5ghz SSID's in to separate VLAN's e.g. IoT devices, Mobile devices etc?
- I'm adding a Logitech Circle 2 (WiFi version) to the network this week too. I'd like that to have full access to the outside world as it is going to be located outside and won't be in sensitive rooms. So I'm thinking I might need another VLAN for that so it doesn't get a firewall rule it shouldn't.
- The three cameras all have Alexa capabilities so I don't want that to be affected by any meddling.
