Hello all,
I have recently moved from the AX86U Pro to the BE86U and setup a BQM a few months ago.
When I check it previously, everything seemed nice and smooth in the graph until I switch the hardware on the 21st November.
Below you can see that everything is nice and calm until the switch and checking back through the days it all shows similar yellow latency spikes.
Is there any reason for this when it should almost be a like for like swap?
Are there any setting I should change or is it perfectly normal and just ignore it?
21st Nov when I switched routers
Today
Today
