Marshalleq
There seems to be a problem with this, or I've not set it up properly. I've had it for a while and only just getting around to logging it.
My setup is 2xAC68U's. The first one is a router connected to a fibre connection and a NAS and serves as the Wireless access point for the apartment. The second is a straight bridge, connected to a Mac Mini only and utilises 5GHz Wireless AC only for this. 2.4 GHz is turned off on the second bridge router.
Running Asus Merlin firmware 378.54_2
There is an apple TV plugged into my stereo, connected by wireless and this doesn't have a problem the connection e.g. with netflix etc.
However, when playing music from the mac to the apple tv it works intermittently. The few times I've had success, it's been intermittent, or worked once and as soon as the music stops a reboot is neccessary of either the computer or the Apple TV. Connecting to the main access point using wireless improves things considerably, but this is a slower connection to the nice AC bridge I've set up as the mac only has wireless N and it should work through the bridge.
I have enabled the multicast settings in the WiFi part of the router. Have changed ODFM setting to 54 as I've read in some Cisco document that this is what apple likes. It seems to me that the router either has a bug, or doesn't have the capability implemented to do apple's airplay. This should really be working with the amount of Apple gear around these days I think (even if I don't like all of it, in fact those are the only two apple devices I'll own).
Any ideas anyone?
Thanks.
Any ideas anyone?
Thanks.
