Is there documentation on this? I will have one router as DHCP already setup. How do I setup other two routers as routers only or will they be router/gateways? I know I turn DHCP off on the other 2 routers. I also know I put the gateway IP and DNS IP of the DHCP Gateway router IP into the other two routers that will be wired bridge to expand the WIFI is all. Is my assumption correct so far?
Is there any documentation or screenshots on how to do this? It was easy for me to set this up on my 3 buffalo routers using the DD-WRT firmware and Wiki documentation.
