Broadcast packets and DOS attack
if the vlans are on the same bridge, then yes unless you filter via ebtables (or the webui you are using provides options that do it for you). ideally, if you really wanted the devices separated, one would NAT each vlan individually and use iptables to filter/connect between vlans as needed. the vlans would each need their own IP subnet. no additional steps should be required in the routing table, the routes should be dynamically generated when you set the IP of each vlan
