Brother printer not recognized
davidc
I've tried two Brother printers, HL-2275DW and MFC-J450DW, via Ethernet and USB.
The RT-AX58U sees what's connected to the USB but I can't print to it.
I assigned an IP to the Mac address of the HL-2275DW - still no joy.
Do I need the Merlin firmware to fix this?
I have 2 brother printers, one on 2.4Ghz wifi and the other one on Ethernet. I have my network settings on the printers on DHCD to make it easy. No issues that way
Connecting a printer via USB or WiFi can create additional complications so concentrate on getting the HL-2275DW working via Ethernet.
Have you configured the HL-2275DW's network interface to use DHCP? After powering on the printer can you see it successfully getting it's address (look in the router's System Log and on the printer itself)?
Assuming the printer has the correct network settings can you ping it from a PC?
I agree... get it working on Ethernet.
Another idea to try for an Ethernet printer... give it a static IP address and then install its driver package on the PC.
OE
Turns out it was a WPS thing. I found a match between the printer and the router ... working now. Thanks!
OE
That is exactly how I got all my HP Printers working perfectly on my LAN. I can print to them from any device via wired Ethernet or wireless Wifi as long as those devices have the necessary drivers installed (computers, phones, tablets, iPads, etc.) and are connected to the Asus router.
