Browsers on tablet/cellphone doesn't work
iku
I recently installed Merlin on my RT-AC68u.
I had to make quite a few changes as I have a VPN and had to let one device go through.
Maybe I made a wrong change somewhere but now my web browsers dont work on cellphones (Apple and Android), ipad, but do work on a laptop, all connected to the same wifi.
Some other applications work on cellphone/ipad, but not the web browsers.
Anyone has an idea?
Thank you
same thing here
i'm using merlins 376.49_5 on my rt-ac66u and since today i cant connect to the web on 2.4ghz on mobile devices. 5ghz seems ok on my nexus5 but i cant use that on my nexus7(2012). really weird, since i havent changed anything, neither on the router nor on the mobile devices...
my girlfriends old iphone 3 isnt able to connect to 2.4ghz either. very strange...
To both posters above, have either of you reset to factory defaults after flashing the new firmware? Did you then manually enter just the required settings to get the router connected to your ISP? Did you 'forget' the old network ssid settings and re-associate again on each device (or better, did you create a new ssid with no spaces or special characters in the ssid name and password)?
If you haven't followed these steps, then depending on which previous firmware you had installed (and if you had followed those steps then too), it is no wonder you have issues.
factory reset
thanks a lot for your quick reply.
yes, i did not reset to factory defaults after the update. i had no problems until now (i updated immediately after the update came out), but i will do that now and see if it works.
edit: yes. the factory reset did the trick!
