Bug 380.66_2 Tools-Other settings screen
eastavin
Screen looks normal when you first enter it. However when you try to create a custom traffic history location the screen goes wonky after you hit APPLY. I am attaching a sample of the resulting display. The ASUS banner at the top with the status, logout and reboot buttons is gone. The first line shows RAM rather than Custom Location I was creating and strangely all the TCP timeout settings down below have vanished. There may be other issues as I did not study it much further. .. oh yes rebooting does not seem to make them come back. Restoring from a saved configuration does return the banner and the tcp timeouts.
Maybe someone could direct this to whomever investigates things like this please? Router is Asus RT-AC68U C1. https://drive.google.com/file/d/0B9Z1uRJJT4StOXNtQ3ZLUGhQNDQ/view?usp=sharing
Many thanks.
Edward
That path makes no sense, it must be location on the router, not on your PC.
