Good day. Would like to contribute what I believe is a bug for investigation.
Setup) Made the following observations while using Adaptive QOS with an Ethernet connected PC. To duplicate go to QOS screen and set Adaptive QOS, Automatic bandwidth selection. Bug observed in priority mode "media streaming" and also in "customize". Did not test the other two options. Now before going further - go back to the bandwidth monitor screen and position it so you can see the upload and download displays.
Next step - load a video streaming application like say Kodi media player and stream a movie from the internet (the higher the resolution the better.. in this case I used 1080p).
Observation) Upon viewing the Asus Merlin router "Bandwidth monitor " tab one will now see the 'upload dial and bar graph' showing the movie that is being streamed as erroneously uploading. (should be showing downloading).
The error in direction is further displayed in the "QOS statistics" tab for video & audio streaming showing the movie traffic as accumulating under the UPLOAD statistics.
The incorrect direction of traffic is also observed with a wifi device. A test with an Android wifi device of exactly the same app streaming/movie shows the traffic reported as uploading when it is really downloading.
Other traffic like browser traffic reports correctly for both Ethernet and wifi devices.
My router is an RT-AC68U C1 with 380.66_2 f/w. EDIT summary: Openvpn server enabled, IPv6in 4 enabled. Disabling IPv6in 4 causes router to correctly display direction of traffic.
