Bug Report: nvram chilli_enable=1 when guest network is removed causes no routing to occur
Acru
I found a bug in official firmware version 3.0.0.6.102_21514, and I am reporting it here (in addition to asus) on the assumption that it exists in merlin as well. Though I haven't tested it on merlin, I didn't see anything in the code or changelog to counter the issue.
On my GT-AX6000, if a guest network is enabled and then removed, the nvram setting chilli_enable is left set to 1.
On the next reboot, prerouting entries are added to the nat-rules, one of which is badly formed due to the guest network not existing;
-I PREROUTING 1 --dst 192.168.52.0/24 -p tcp --dport 80 -j REDIRECT --to-ports 3990
-I PREROUTING 2 --src 192.168.52.0/24 --dst (null) -p tcp --dport 80 -j REDIRECT --to-ports 8083
This occurs in firewall.c, nat_setting() on line 1751 or nat_setting2() on line 2217 for dual wan, when lan_ip is null.
This shows up in the router log as "services: apply rules error(21101)"
The result is that no routing occurs until chilli_enable is set to 0 and the router is rebooted.
That code only gets compiled if CAPTIVE_PORTAL is enabled - it`s not enabled in Asuswrt-Merlin.
