Bug with latest 3.0.0.4.378_4850 : Gui index window messed up
  • Thread starter Thread starter NickJ
  • Start date Start date
N
NickJ
Guest
Interfacing my RT-AC68U wireless router through Mac OS X.
Went this AM from 4585 to 4850 using the upload function on the interface.
After restart I get a very partial interface window as per attached.
Fortunately the router works well. I just can't view/change any setting and even less upload an older firmware or a future one....
I am concerned that if I do a reset, the router will just restart with this latest buggy 4850 but then without any of the services I setup, which would bring me to a worse situation. (I do have a saved settings file but this is no good if the same buggy screen comes up).
Tried the "Advanced_FirmwareUpgrade_Content.asp" where I can select the previous 4585 firmware alright but then the action button "upload" does not react at all. Am I using the wrong .asp command ? Is there another one that would work ? How can I get out of this mess ?
Besides, is there a list of all Asus ".asp" commands somewhere that would help me now or in the future to access individual pages, for ex. to view or change settings etc. ?
Thanks for your advice. NickJ
I have seen this before, solved it by refreshing the page or deleting the browser cache and restart. Have you tried with a different browser?
Yes I tried with another browser, reloaded etc... no change, unfortunately.
Thanks but to be able to change "language" you need to have access to a normal interface that let's you do this.
If you look at the original posting, the choice is limited.
Do you have the ".asp" command to change the language ? I also tried to access my router from a PC within my network: same limited interface.
Best regards, NickJ
Wouldn't be the first time Asus's webui breaks for French or Italian, due to the insertion of unescaped quotes in the dictionary files. :(
If you access the webui using an English browser, it should in theory use the English version of its pages.
No, unplugging does not solve. I would try to use an English browser, so...
EDIT: switch browser language does not solve anything.
Well finally, after a RESET that produced no results, I had my son (using a PC whereas I use a Mac) using the RECOVERY utility of Asus, back to the previous (working) firmware. This worked fine, all is back to normal.
Strangely enough, I thought that performing a reset would get my settings lost : not the case. Reset, restore... all my original settings where present and the unit works like a charm.
Asus European support were not willing to provide me with anything but these two options : they did not even address my request to get some basic .asp command lines (such as http://192.168.1.1/Advanced_FirmwareUpgrade_Content.asp) not even why it may not work that way. Rather deceived by their very basic support but now that it works, I will collect all these .asp command lines manually.
Not all of them are present on every router models, many of these are also only used internally, and these may change at any time (which is why basic tech support cannot provide that kind of technical information), but here's the list of pages available in 378_4980:
merlin@mint-dev ~/asuswrt.378-4980-ac3200/release/src/router/www $ ls *.asp | cut -d " " -f 1
AdaptiveQoS_Adaptive.asp
AdaptiveQoS_Bandwidth_Monitor.asp
AdaptiveQoS_ROG.asp
AdaptiveQoS_WebHistory.asp
Advanced_ACL_Content.asp
Advanced_AiDisk_ftp.asp
Advanced_AiDisk_samba.asp
Advanced_AiDisk_webdav.asp
Advanced_APPList_Content.asp
Advanced_ASUSDDNS_Content.asp
Advanced_BasicFirewall_Content.asp
Advanced_DHCP_Content.asp
Advanced_Exposed_Content.asp
Advanced_Feedback.asp
Advanced_Firewall_Content.asp
Advanced_Firewall_IPv6_Content.asp
Advanced_GWStaticRoute_Content.asp
Advanced_IPTV_Content.asp
Advanced_IPv6_Content.asp
Advanced_KeywordFilter_Content.asp
Advanced_LAN_Content.asp
Advanced_MACFilter_Content.asp
Advanced_Modem_Content.asp
Advanced_NATPassThrough_Content.asp
Advanced_OperationMode_Content.asp
Advanced_PerformanceTuning_Content.asp
Advanced_PortTrigger_Content.asp
Advanced_QOSUserPrio_Content.asp
Advanced_QOSUserRules_Content.asp
Advanced_SettingBackup_Content.asp
Advanced_Smart_Connect.asp
Advanced_SNMP_Content.asp
Advanced_SwitchCtrl_Content.asp
Advanced_System_Content.asp
Advanced_TimeMachine.asp
Advanced_TOR_Content.asp
Advanced_TR069_Content.asp
Advanced_URLFilter_Content.asp
Advanced_VirtualServer_Content.asp
Advanced_VPNClient_Content.asp
Advanced_VPN_OpenVPN.asp
Advanced_VPN_PPTP.asp
Advanced_WAdvanced_Content.asp
Advanced_WAN_Content.asp
Advanced_WANPort_Content.asp
Advanced_Wireless_Content.asp
Advanced_WMode_Content.asp
Advanced_WSecurity_Content.asp
Advanced_WWPS_Content.asp
aicloud_qis.asp
aidisk.asp
AiProtection_AdBlock.asp
AiProtection_Group.asp
AiProtection_HomeProtection.asp
AiProtection_HomeSecurity.asp
AiProtection_WebProtector.asp
ajax_coretmp.asp
ajax_ddnscode.asp
ajax_dms_status.asp
ajax_openvpn_server.asp
ajax_qos_default.asp
ajax_signals.asp
ajax_uploadicon.asp
ajax_wlc_state.asp
api.asp
aplist.asp
APP_Installation.asp
apps_test.asp
apscan.asp
automac.asp
blocking.asp
cloud_main.asp
cloud_router_sync.asp
cloud_settings.asp
cloud_status.asp
cloud_sync.asp
cloud_syslog.asp
DDNS_info.asp
detect_firmware.asp
detectWAN.asp
diskmon_test.asp
disk_scan.asp
Feedback_Info.asp
find_device.asp
getAppTraffic.asp
getfoldertree.asp
getsharelink.asp
getsl.asp
getTraffic.asp
gettree.asp
getWanTraffic.asp
get_webdavInfo.asp
getWebHistory.asp
Guest_network.asp
index.asp
Logout.asp
Main_AdmStatus_Content.asp
Main_Analysis_Content.asp
Main_ConnStatus_Content.asp
Main_DHCPStatus_Content.asp
Main_IPTStatus_Content.asp
Main_IPV6Status_Content.asp
Main_LogStatus_Content.asp
Main_Netstat_Content.asp
Main_RouteStatus_Content.asp
Main_Spectrum_Content.asp
Main_TrafficMonitor_daily.asp
Main_TrafficMonitor_last24.asp
Main_TrafficMonitor_realtime.asp
Main_WOL_Content.asp
Main_WStatus_Content.asp
manifest.asp
mediaserver.asp
multi_vts_rule.asp
Nologin.asp
ParentalControl.asp
PrinterServer.asp
QoS_EZQoS.asp
remote.asp
Restarting.asp
result_of_get_changed_status_QIS.asp
SITE_info.asp
start_autodet.asp
status.asp
switch_AiDisk_app.asp
TrafficAnalyzer_Statistic.asp
update_applist.asp
update_appstate.asp
update_clients.asp
update_cloudstatus.asp
update_diskinfo.asp
UpdateError.asp
update_IPv6state.asp
Updating.asp
UploadError.asp
Uploading.asp
ureip.asp
WAN_info.asp
wds_aplist_2g.asp
wds_aplist_5g_2.asp
wds_aplist_5g.asp
YandexDNS.asp
Thanks a lot, will be useful.
Asus (basic) Tech support (based in Germany) had my exact model number and firmware... they are just not much going "out of their way".
Appreciate all of you that cared replying to my original post... thanks !
