Building current release for RT-AC56U fails
qus
Hello,
Due to firmware bug of my fresh IcyDock, I need to patch some code and compile my own Merlin. I'm using this guide:
https://github.com/RMerl/asuswrt-merlin/wiki/Compile-Firmware-from-source-using-Ubuntu
Unfortunately the "manual" way (with just make) fails with:
make[7]: Entering directory `/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/src'
/bin/bash ../libtool --tag=CC --mode=link arm-brcm-linux-uclibcgnueabi-gcc -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../sqlite -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../pcre-8.31 -I./release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/include -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../sqlite -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../curl-7.21.7/include -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../../include -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../nvram_arm -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../shared -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../libdisk -DHAVE_OPENSSL_SSL_H=1 -DHAVE_LIBSSL=1 -DEMBEDDED_EANBLE=1 -Wall -W -Wshadow -pedantic -std=gnu99 -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../samba-3.5.8/source3/include -I/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../libxml2/include -module -export-dynamic -avoid-version -no-undefined -L./release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/lib -ldl -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../pcre-8.31/.libs -lpcre -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../libxml2/.libs -lxml2 -lm -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../openssl -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../curl-7.21.7/lib/.libs -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../openssl/lib -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../openssl/ -o liblightsql.la -rpath /root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/_inst/lib liblightsql_la-sql.lo -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../sqlite/.libs -lsqlite3 -L./release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/lib -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../shared -lshared -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../nvram_arm -lnvram -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../libdisk -ldisk -lpthread -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../openssl -lcrypto -lssl -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../curl-7.21.7/lib/.libs -lcurl -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../libxml2/.libs -lxml2 -lpthread -dl -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../samba-3.5.8/source3/bin -lsmbclient -L/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/../libxml2/.libs -lxml2 -lm
../libtool: line 5986: cd: ./release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/lib: No such file or directory
libtool: link: cannot determine absolute directory name of `./release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/lib'
make[7]: *** [liblightsql.la] Error 1
make[7]: Leaving directory `/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/src'
make[6]: *** [all] Error 2
make[6]: Leaving directory `/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29/src'
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory `/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29'
make[4]: *** [all] Error 2
make[4]: Leaving directory `/root/asuswrt-merlin/release/src/router/lighttpd-1.4.29'
make[3]: *** [lighttpd-1.4.29] Error 2
make[3]: Leaving directory `/root/asuswrt-merlin/release/src/router'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/root/asuswrt-merlin/release/src-rt-6.x.4708'
make[1]: *** [bin] Error 2
make[1]: Leaving directory `/root/asuswrt-merlin/release/src-rt-6.x.4708'
make: *** [default] Error 2
And the automated (with debian-build-image) fails with... erm... just finished... exactly the same error.
Build environments were always my nightmate, I'm make-illiterate. Any help would be appreciated!
It's all in there:
It's all in there:
Indeed, it is. But it doesn't say how to fix it, or am I partially blind? If it is complaining about missing uclibc for arm architecture how do I install it?
But the real problem is this very directory exists:
oot@Ubuntu:~/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/lib# ls -al
total 4080
drwxr-xr-x 4 root root 4096 sie 8 08:35 .
drwxr-xr-x 8 root root 4096 sie 8 08:35 ..
drwxr-xr-x 3 root root 4096 sie 8 08:35 gcc
drwxr-xr-x 2 root root 4096 sie 8 08:35 ldscripts
-rwxr-xr-x 1 root root 21388 sie 8 08:35 ld-uClibc-0.9.32.1.so
-rwxr-xr-x 1 root root 21388 sie 8 08:35 ld-uClibc.so.0
-rw-r--r-- 1 root root 1391212 sie 8 08:35 libc.a
-rwxr-xr-x 1 root root 13195 sie 8 08:35 libcrypt-0.9.32.1.so
-rwxr-xr-x 1 root root 13195 sie 8 08:35 libcrypt.so.0
-rwxr-xr-x 1 root root 440575 sie 8 08:35 libc.so
lrwxrwxrwx 1 root root 21 sie 8 08:35 libc.so.0 -> libuClibc-0.9.32.1.so
-rwxr-xr-x 1 root root 9203 sie 8 08:35 libdl-0.9.32.1.so
-rwxr-xr-x 1 root root 9203 sie 8 08:35 libdl.so.0
-rw-r--r-- 1 root root 135 sie 8 08:35 libgcc_s.so
-rw-r--r-- 1 root root 181180 sie 8 08:35 libgcc_s.so.1
-rwxr-xr-x 1 root root 1102 sie 8 08:35 libgmp.la
lrwxrwxrwx 1 root root 16 sie 8 08:35 libgmp.so -> libgmp.so.10.0.2
lrwxrwxrwx 1 root root 16 sie 8 08:35 libgmp.so.10 -> libgmp.so.10.0.2
-rwxr-xr-x 1 root root 434829 sie 8 08:35 libgmp.so.10.0.2
-rw-r--r-- 1 root root 228346 sie 8 08:35 libiberty.a
-rwxr-xr-x 1 root root 1107 sie 8 08:35 libltdl.la
lrwxrwxrwx 1 root root 16 sie 8 08:35 libltdl.so -> libltdl.so.7.2.2
lrwxrwxrwx 1 root root 16 sie 8 08:35 libltdl.so.7 -> libltdl.so.7.2.2
-rwxr-xr-x 1 root root 37335 sie 8 08:35 libltdl.so.7.2.2
-rwxr-xr-x 1 root root 68623 sie 8 08:35 libm-0.9.32.1.so
-rwxr-xr-x 1 root root 1259 sie 8 08:35 libmpc.la
lrwxrwxrwx 1 root root 15 sie 8 08:35 libmpc.so -> libmpc.so.2.0.0
lrwxrwxrwx 1 root root 15 sie 8 08:35 libmpc.so.2 -> libmpc.so.2.0.0
-rwxr-xr-x 1 root root 89375 sie 8 08:35 libmpc.so.2.0.0
-rwxr-xr-x 1 root root 1199 sie 8 08:35 libmpfr.la
lrwxrwxrwx 1 root root 16 sie 8 08:35 libmpfr.so -> libmpfr.so.4.0.1
lrwxrwxrwx 1 root root 16 sie 8 08:35 libmpfr.so.4 -> libmpfr.so.4.0.1
-rwxr-xr-x 1 root root 362124 sie 8 08:35 libmpfr.so.4.0.1
-rwxr-xr-x 1 root root 68623 sie 8 08:35 libm.so.0
-rwxr-xr-x 1 root root 4772 sie 8 08:35 libnsl-0.9.32.1.so
-rwxr-xr-x 1 root root 4772 sie 8 08:35 libnsl.so.0
-rwxr-xr-x 1 root root 83619 sie 8 08:35 libpthread-0.9.32.1.so
-rwxr-xr-x 1 root root 83619 sie 8 08:35 libpthread.so.0
-rwxr-xr-x 1 root root 4776 sie 8 08:35 libresolv-0.9.32.1.so
-rwxr-xr-x 1 root root 4776 sie 8 08:35 libresolv.so.0
-rwxr-xr-x 1 root root 5051 sie 8 08:35 librt-0.9.32.1.so
-rwxr-xr-x 1 root root 5051 sie 8 08:35 librt.so.0
-rwxr-xr-x 1 root root 13907 sie 8 08:35 libthread_db-0.9.32.1.so
-rwxr-xr-x 1 root root 13907 sie 8 08:35 libthread_db.so.1
-rwxr-xr-x 1 root root 440575 sie 8 08:35 libuClibc-0.9.32.1.so
-rwxr-xr-x 1 root root 4955 sie 8 08:35 libutil-0.9.32.1.so
-rwxr-xr-x 1 root root 4955 sie 8 08:35 libutil.so.0
