iposminus said:I'm building "starter" DIY NAS and I need some advices or directions. For now I'll have only three WD Green 2TB HDDs, probably more if need arises (and of course I'll have enough money ).
I was thinking about buying this motherboard and this controller.
I'm going to have RAID5 for redundancy. On this network I'll have one Windows 7 system, one Windows XP and very likely HTPC (probably running Windows 7).
Which software should I use? I'm leaning toward FreeNAS, but I don't have experience with none of them. If you need any other details, just ask.
Please advise.
Thank you in advance.
This was original message in Sticky Building High Performance NAS / HTPC, but 00Roush suggested to open a new thread and I did.
First thanks both, 00Roush and GregN for replies.
I asked seller how much postage costs for that motherboard to my country and it's almost same value as the motherboard. :S
But I've found this one (2 x dual XEON 2.8Ghz, X5DP8, 2GB ,SCSI 36GB hot swap, 2HU 19" with rails) near me and I'm trying to contact the seller, but no luck.
The controller is already ordered. For the HDDs I've decided to use Samsung F4. Is there a big difference between 7200rpm and 5400rpm?
PSU is going to be one of the Corsairs, don't know exactly yet, but SINGLE-RAIL is a must. When checking PSU if it's single-rail or not, does it say on manufacturers site or where/how do you check?
For the gigabit network I'll use HP ProCurve 1410-8G and a WRT54GL for wireless. I doesn't have N support, so HD streaming probably won't work, but for now I don't intend to stream HD over wireless.
And last, but not least important question...
GregN said:If you are going hardware RAID I recommend FreeNAS.
I'm a little confused by this statement. Isn't FreeNAS software raid? Or am I missing something?
This is it for now, please point out anything that could be wrong with this setup, any suggestion or whatever, I'll be glad to read it, respond and ask.
