Bypass Router
Paradoxgrowth
Hi everyone,
I have a Qnap server and a RT-AC68U. They have been working great together with no problems. I can always hit the qnap page it produces from the outside LAN. However, recently I forwarded all my traffic through a VPN by connecting the Asus router to it as a client (OpenVPN). The problem is the VPN Proxy does not allow incoming traffic. The Server has two NICs so I thought one could go through the proxy and the other could bypass it. I am not sure how to buy pass it! Would I use a switch? Switches don't have NAT. What are my options? Thanks!!
Hi System,
The page is public and I really don't need VPN to gain access because it uses SSH. Port forwarding is not the issue I already took that step. In addition, before I turned the proxy on, it worked. Maybe I am not being clear. The router is forwarding all traffic through a VPN proxy. I have it so my ISP can't spy on my traffic. However, the VPN does not allow incoming traffic so I can no longer reach my QNAP from the outside. Since it has two ethernets I would be willing to connect one to the router and one to a switch or something that bypasses the router. That way I can still reach it from the outside, however, I don't think you can connect a switch to a modem, router, and computer. The switch doesn't perform nat. See diagrams.
Hi System,
The page is public and I really don't need VPN to gain access because it uses SSH. Port forwarding is not the issue I already took that step. In addition, before I turned the the proxy it worked. Maybe I am not being clear. The router is forwarding all traffic through a VPN proxy. I have it so my ISP can't spy on my traffic. However, the VPN does not allow incoming traffic so I can no longer reach my QNAP from the outside. Since it has two ethernets I would be willing to connect one to the router and one to a switch or something that bypasses the router. That way I can still reach it from the outside, however, I don't think you can connect a switch to a modem, router, and computer. The switch doesn't perform nat. See diagrams.
Your forwarding all port 80/443 traffic i presume. Simply change the ports.
i dont know if you can but if you can seperately port forward the qnap rather than a blanket rule that could work.
In the case of iptables put your qnap forwarding rule before your blanket redirect rule for the proxy.
@Paradoxgrowth Your idea of putting a switch in front of your cable modem won't work unless your ISP has provisioned your line for 2 separate internet connections.
Yeah I agree! Could you have a switch (or something) with NAT then plug in the router? In my past experience of hooking two routers together has been a fail. I'm not sure if it is the two NAT or DHCP.
