Bypass RT-N66U setup wizard?
trek_520
Hi
Is there a way to bypass the connection wizard the first time you log into the router? I have had varying degrees of success with the wizard on various machines.... I am not interested in using the setup disc.
Thanks in advance.
Hi
Thanks in advance.
You don't need the Setup CD to use the QiS wizard BTW.
If you want to bypass it, just directly access the router's IP after the QiS page comes up.
Thanks Merlin - your the best.
To be clear -
1) log into the router let the wizard page load
2) reenter the router IP and I am good to go?
Cheers.
To be clear -
Cheers.
Correct. If that doesn't work, then try also specifying the page itself:
http://192.168.1.1/index.asp
