Any ideas about why cake suddenly stops for no apparent reason? Sometimes it restarts again maybe 1 min later on its own, but sometimes not. When I check it around 7am first thing in the morning I see that it is stopped. I have had cake enabled for a while, but just recently added the CakeQOS-Merlin script. Going to that screen tells me that cake is not running. If I run cake-qos from the terminal, and do a Download stats, I will see that it is running, but if I do the Upload stats, then attempt to get the Download stats again, it tells me that cake is not running. I rebooted 2 days ago but cannot tell if this behavior only started since that time or it is was doing this before. I also do not know if it was doing this before I installed the CakeQOS-Merlin script.
Before I did a manual Apply from the CakeQOS-Merlin screen, and saw that cake was not running, here is what was in my log file:
Apr 12 07:09:24 RT-AC86U-1BD0 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Apr 12 07:09:27 RT-AC86U-1BD0 rc_service: httpds 30772:notify_rc start_cake-qosstatsupdate
Apr 12 07:09:27 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event (args: start cake-qosstatsupdate)
Apr 12 07:09:27 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event-end (args: start cake-qosstatsupdate)
Apr 12 07:09:56 RT-AC86U-1BD0 rc_service: httpds 30772:notify_rc start_cake-qosstatsupdate
Apr 12 07:09:56 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event (args: start cake-qosstatsupdate)
Apr 12 07:09:56 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event-end (args: start cake-qosstatsupdate)
Apr 12 07:10:10 RT-AC86U-1BD0 rc_service: httpds 30772:notify_rc restart_qos;restart_firewall
Apr 12 07:10:10 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event (args: restart qos)
Apr 12 07:10:10 RT-AC86U-1BD0 CakeQOS-Merlin: Configuring Cake options...
Apr 12 07:10:13 RT-AC86U-1BD0 BWDPI: fun bitmap = 47f
Apr 12 07:10:13 RT-AC86U-1BD0 custom_config: Appending content of /jffs/configs/cake-qos.conf.add.
Apr 12 07:10:13 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event-end (args: restart qos)
Apr 12 07:10:13 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Apr 12 07:10:14 RT-AC86U-1BD0 custom_script: Found nat-start, but script is not set executable!
Apr 12 07:10:14 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Apr 12 07:10:14 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Apr 12 07:10:28 RT-AC86U-1BD0 rc_service: httpds 30772:notify_rc start_cake-qosstatsupdate
Apr 12 07:10:28 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event (args: start cake-qosstatsupdate)
Apr 12 07:10:28 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event-end (args: start cake-qosstatsupdate)
Apr 12 07:10:38 RT-AC86U-1BD0 rc_service: service 1737:notify_rc restart_dnsmasq
Apr 12 07:10:38 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event (args: restart dnsmasq)
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[31522]: exiting on receipt of SIGTERM
Apr 12 07:10:39 RT-AC86U-1BD0 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
Apr 12 07:10:39 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Apr 12 07:10:39 RT-AC86U-1BD0 (dnsmasq.postconf): Updating /etc/dnsmasq.conf for unbound.....
Apr 12 07:10:39 RT-AC86U-1BD0 stubby[1895]: Stubby version: Stubby 0.4.0
Apr 12 07:10:39 RT-AC86U-1BD0 stubby[1895]: Read config from file /etc/stubby/stubby.yml
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: started, version 2.85 cache disabled
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset no-auth cryptohash DNSSEC no-ID loop-detect no-inotify no-dumpfile
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: warning: interface br1 does not currently exist
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: warning: interface pptp* does not currently exist
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: asynchronous logging enabled, queue limit is 5 messages
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq-dhcp[1899]: DHCP, IP range 192.168.102.2 -- 192.168.102.254, lease time 1d
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq-dhcp[1899]: DHCP, IP range 192.168.101.2 -- 192.168.101.254, lease time 1d
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq-dhcp[1899]: DHCP, IP range 192.168.2.128 -- 192.168.2.191, lease time 1h
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: using nameserver 127.0.0.1#53535
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: using only locally-known addresses for domain CAPELLA
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: read /etc/hosts - 7 addresses
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq[1899]: read /jffs/addons/YazDHCP.d/.hostnames - 10 addresses
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq-dhcp[1899]: read /jffs/addons/YazDHCP.d/.staticlist
Apr 12 07:10:39 RT-AC86U-1BD0 dnsmasq-dhcp[1899]: read /jffs/addons/YazDHCP.d/.optionslist
Apr 12 07:10:39 RT-AC86U-1BD0 custom_script: Running /jffs/scripts/service-event-end (args: restart dnsmasq)
It looks to me like there are back-to-back qosstatusupdates going on. I have no idea if that is expected but it seems odd.
Any insights into what's going on, and what I need to do to fix it? Is it time for me to bite the bullet and do a nuclear reset and update to 10_0 and reinstall every thing?
Update: I just looked at CakeQOS (about 6 hrs later than my initial post), and it said cake was not running. I have no idea how long its been in that state. I kick-started it and now its going. Maybe I'll try to do a script to periodically check if cake is running, and to restart it if it's not.
