Can anyone explain the use of the 5 vpn clients?
wimfr
is there anyone here that can explain to me how to use the 5 vpn client options.
I can only manage to actually connect to one client. Can get a second one also get connected to my vpn provider but cannot use it (everything goes through the first client) and when I enable a second client I can also not connect anymore to my VPN server.
any help will be much appreciated.
They are meant for connecting to different servers. You cannot connect twice to the same server, as the routes will conflict.
OK thanks, now it is clear.(I think)
I just populate them with the most used servers and then turn the one that I want ON.
I cannot connect to 2 different servers at the same time ?
thank you.
thank you.
Depends on the servers and how you intend to use them. Have to use different rules, and they must also connect to different subnets.
