Can I add a WNHDE111 to my DIR-655 & DAP-1522
Karlsbad
Using the DAP-1522 in AP mode with a few devices hard wired to it. To see if I can get some more speed for xbox live etc.
How do you propose to connect the WNHDE111? You can't bond multiple adapters together for more bandwidth.
If anything, you may get lower throughput by using 5 GHz, depending on distance, walls, etc.
You'll probably see about the same speed at 2.4 GHz.
Hmmm ok I may try it anyway from someplace I can return it to. I'll let you know what results I get.
X Need to add a "partner" to my asus ac86u Wi-Fi Buying Advice 9
