can i remove sleep 20 in my services-start script
chu
i have a usb flash disk plug in my asus ac 1900p,the services-start i wote andas below:
#!/bin/sh
sleep 20
modprobe xt_set.ko
ipset -N setgoogle iphash
iptables -t nat -A PREROUTING -p tcp -m set --match-set setgoogle dst -j REDIRECT --to-port 8080
/opt/etc/init.d/rc.unslung start
#!/bin/sh
sleep 20
modprobe xt_set.ko
No, however I suggest you to put a simple loop in your script so entware will be started asap:
#!/bin/sh
RC='/opt/etc/init.d/rc.unslung'
i=30
until [ -x "$RC" ] ; do
  i=$(($i-1))
  if [ "$i" -lt 1 ] ; then
    logger "Could not start Entware"
    exit
  fi
  sleep 1
done
$RC start
modprobe xt_set.ko
I wait until my two USB-Sticks are mounted to start Entware. Here an excerpt of my post-mount user script:
if [ $1 = "/tmp/mnt/ac87u" ] # Entware partition
then
ln -nsf $1/entware-ng.arm /tmp/opt
if mount | grep /tmp/mnt/Data > /dev/null; # Data partition for Transmission
then
else
/usr/bin/logger -t START_$(basename $0) "USB stick Data partition not mounted yet!"
fi
fi
Maybe this is the more save and clean solution as it really waits until the needed partitions are mounted... :rolleyes:
#!/bin/sh
i=30
  i=$(($i-1))
    exit
  fi
  sleep 1
done
$RC start
modprobe xt_set.ko
thanks, can i execute below script first? seemed it does'nt depends on entware.
modprobe xt_set.ko
Mine was just an example. If you want to be executed first, you can put those 3 lines at the top of your script. It doesn't change much btw.
Don't put iptables rules in services-start, because they will be overwritten every time the firewall gets restarted.
hmm, so put these in "firewall-start" ?
including the "modprobe xt_set.ko" line too?
for example can i do below?
firewall-start
#!/bin/sh
modprobe xt_set.ko
firewall-start
The modprobe and ipset commands can be kept in services-start since they only needs to be executed once.
nat PREROUTING rules should ideally be put in nat-start (not firewall-start).
dear rmerlin, is this ok?
services-start
#!/bin/sh
modprobe xt_set.ko
i=30
i=$(($i-1))
exit
fi
sleep 1
done
$RC start
nat-start
#!/bin/sh
Should be good.
