Can I use my Asus 68U router as a NTP time source for my LAN
Bruce_H
I am running Asuswrt-Merlin firmware on my RT-AC68U router, and I am wondering if it is possible to have my internal Network devices use the router as a NTP time source since it is already syncing to an external time source (pool.ntp.org). If so then where can I find information on how to do this?
Bruce H.
....where can I find information on how to do this?
There are different options depending on which version of ntpd you wish to use ranging from using the built-in Busybox version (/usr/sbin/ntpd --help) i.e. simply edit
/jffs/scripts/services-start
/usr/sbin/ntpd -l
or installing @kvic's ntpd (Tools - NTP Daemon Performance Stats GUI optional) or the FULL ntpd from Entware.
This thread should give you comprehensive details including a link to Kvic's ntpd project and example scripts etc.
https://www.snbforums.com/threads/ntp-server.34828/#post-282020
I use this setup and it works like a charm for all my local PCs. :D
Bad idea to do this as most (none?) of the asus routers have battery backup.
Last thing you want is a client syncing when the router is restarting and it hasent set its time yet.
Bad idea to do this as most (none?) of the asus routers DO NOT have battery backup.
Yep, but therefore I start the NTP server only AFTER the router has synced the time... :D
https://github.com/RMerl/asuswrt-merlin/wiki/Setting-up-a-NTP-Server-for-your-local-lan
began with a wiki article seen this question turn up from time to time so thought it might be better to make it into a wiki page, feel free to improve upon it.
Perhaps it would be prudent to address concerns and follow the advice of @joegreat
https://www.snbforums.com/threads/c...ntp-time-source-for-my-lan.38370/#post-316684
and update the wiki
/jffs/scripts/srvices-start
if [ "$(nvram get ntp_ready)" == "1" ];then  # Only start the NTP server if router has itself synchronised with Internet
   ntpd   -l
else
   logger -st "($(basename $0))" $$ "***ERROR Router cannot get initialise NTP Server!"
fi
Bit of a thread dig here but I figured its better than making a new one.
I've followed all the steps from the wiki however the service doesn't appear to start on its own if the router is rebooted.
I'm using WinSCP and if I right click on the post-mount script and "execute" it I get this message
Command '"./post-mount"'
failed with return code 0 and error message
./post-mount: line 15: Internet: not found
(post-mount): 4364 ***SUCCESS Router copied
ntp.conf-file to /etc!
(post-mount): 4364 ***SUCCESS Router initialized NTP
Server!.
If i then set my Windows PC to use my routers IP for NTP it works.
However if I reset the router and try again on the Windows PC it will not work and i'd have to manually execute the post-mount script.
Any help would be appreciated thanks.
