ADFHogan
I was wondering, is it possible to instruct the DNS server in the router to forward a specific domain's queries to a specific server?
I have one of the routers I look after (an RT-AC5300) set up to use OpenDNS as its upstream, with AiProtect enabled also.
Today, after quite some time (more than a year I'd guess), one of the computers started exhibiting login issues via RDP ("an authentication error has occurred" "the local security authority cannot be contacted"). I was unable to connect to the computer remotely unless I overrode NLA and then one of the domain user accounts would fail. I followed all of the diagnostics, then went to remove and re-add the affected computer from the domain. When I went to re-add it to the domain, it complained when I used the ".local" variant of the domain, complaining it couldn't resolve a particular DNS entry for the DC.
I was able to successfully re-pair the machine to the domain using the old single word version of the domain, and things are continuing, but I'm not sure this is going to be a long term solution, particularly if Windows 10 systems start exhibiting the same symptoms.
Is there a way to instruct the DNS service within the router to route all requests for a specific domain to a different DNS server other than the default.
Eg. Request for example.local zone forwarded to IP of DC instead of OpenDNS
It's a small office, with guests sharing their internet, but on a guest WiFi. Guest segment can't be isolated to internet only if internal DNS on non-guest segment in use, hence having router do DNS + DHCP.
