Cannot add/alter device icons anymore?
RSwipeCA
Hi all.
I am running an RT AC 68U with 380.68 firmware.
I went into the client status section of the router to add an icon for a recently added piece of equipment, and found I cannot access the page to add or change the network item icons. All the pictures I added in the past are displayed but I cannot change those or add new ones? Am I having a brain fart here or what?
Thanks in advance.
Damian.
AC3200 and latest firmware , I see no problem with the icons.
Have you cleared the browser cache ? You could try powering the router off for a couple of minutes then see what happens when you power back on.
Thanks very much for your reply AndreiV. Your reply got me thinking. I have been running Firefox for years without issue. Clearing browser cache made no difference, and I know the router has been rebooted several times recently without any change. Upon installing and running Chrome everything works as it should! So I am guessing something isn't playing well with Firefox? At least on my system. Firefox is up to date also. Thanks again for your input.
