wingman1487
Router: RT-AX88U
Merlin Firmware: 386.3_2
VPNs Setup: 1x Server, 1x Client
Issue: I am unable to add or remove users to my OpenVPN Server.
Reproduction:
This used to work just fine, connections in on the VPN server have no issues, just one day I was unable to add/remove users from my server. I've tried clearing cache/data of my main browser (Brave) and even moved to Edge as a test, all with the same results. Checking the logs I don't see anything there that gives me any idea of what's happening. Here are the logs when set to
Reproduction:
- When logged into the router go to (VPN > VPN Server > Server 1).
- I can see a full list of my Users, their connection status, etc.
- Add in Username and Password
- Hit the +
- Hit apply
- Progress percentage pops up and completes, the user that was added is not in the list
- Try the same thing however hit the minus (-) next to a user and the similar results with the exception being that the user still remains in the list after percentage completes
- VPN Server Log verbosity - 0
- Default message leg level - debug
- Log only messages more urgent than - all
Dec 7 18:31:02 rc_service: httpd 25283:notify_rc restart_chpass;restart_vpnserver1
Dec 7 18:31:02 custom_script: Running /jffs/scripts/service-event (args: restart chpass)
Dec 7 18:31:02 custom_script: Running /jffs/scripts/service-event (args: restart vpnserver1)
Dec 7 18:31:02 ovpn-server1[3871]: --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Dec 7 18:31:02 ovpn-server1[3872]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Dec 7 18:31:02 ovpn-server1[3872]: Could not determine IPv4/IPv6 protocol. Using AF_INET
