DesertSweeper
Has anyone found a way to edit the Surveillance Station footage, or convert it to a format that is recognised by decent Video Editors like Vegas or VPX?
So I go to download some video footage to hand over to the authorities and I need to edit out and clean it up to reduce down to the relevant sections. The first thing I discover is that you cannot import any clips that are not complete. So if you choose a start and end-time and download that - it is only viewable in a player - no Video Editor recognises the file as a valid MP4 video file. Ok so you get past that and dump the entire recording and now various video editors see it as a valid MP4 file. BUT there is not much one can do with it:
Vegas Pro 15: Crashes on placing the clip into the time-line
Video Pro X: "The file is not recognised as a supported Video Format"
Corel VideoStudio 2018: This cheap editor actually accepts the file, allows you to edit it but does not see the Audio stream - in fact it believes the source video does not contain any audio at all - even though it clearly does.
Details:
Synology DS716+II
DSM 6.1.5-15254 (2018/01/26)
Camera: Hikvision IR Mini Dome DS-2CD2542FWD-IS with Firmware V5.4
Details:
Synology DS716+II
