Hello all,
I have a Asus RT-AC66u router with firmware 376.49_5. This is the Merlin firmware, but the same thing happens with the original Asus firmware.
This is my set-up:
ISP modem -> Asus RTAC66U (over wireless connected) -> Clients
It all works, sort of. There are two problems that I see.
1) Any wireless client cannot connect to the 2.4Ghz network. Just before it connects the signal strenght goes from very good to poor, but I'm standing right beside the router. The wireless clients connect fine on the 5Ghz network.
2) I have one pc wired from the lan 1 port to the pc. This works too, but once in ahwile the connection drops.
This has an effect in online games for example when you are suddenly disconnected. I see the following in the logs:
notify wanduck: wlc_state change!
kernel: dnsmq ctrl: cb2a8c0 ^Frouter^Dasus^Ccom
I did alittle googeling and found that this is due to the router asking for a dhcp adress but not getting one fast enough it seems?
What have I tried:
Ofcourse, I already tried different things.
1) use merlin firmware instead of asus one -> No effect
2) Use a static ip-adress for the router -> No effect
3) Reset to default then apply settings again -> no effect
Ussaly I try to solve things on my own, but I am really at a loss here. ANy help would be great!
This is my set-up:
What have I tried:
