TanyaC
Sorry, this is going to be long.
I have an ASUS RT-AC88u connected to a FTTP 100/20 connection via an NBN NTD.
A month ago the connection became unstable and eventually disconnected. After going through several checks I found that doing a factory reset on the router and then restoring my configuration fixed the issue.
Yesterday the same thing happened, however, this time I cannot maintain a connection. It seems whenever I make any change to the router configuration it disconnects, or maybe that's just a coincidence as I have extensive DHCP reservations and firewall filters that take quite a while to key in manually.
So I connected a cable from PC to NTD direct and the connection is stable, which seems to indicate that this is a CPE issue.
So I replaced the ethernet cables from the router to the NTD and router to switch. I power cycled everything. I've upgraded the Merlin firmware and then downgraded it.
None of that worked so I put in my spare ASUS RT-AC68u and it has exactly the same issues. Will connect for a while then disconnect.
Typically once it disconnects it stays disconnected until I factory reset the router, although while I was talking to my ISP it dropped and reconnected a few times.
I am also now getting certificate errors in my Firefox. The router defaults to 192.168.1.1 but I have a server on that address so I always change my router to 192.168.1.254.
The ISP says they can't escalate the issue because a direct connection from PC to NTD is stable and speeds are good.
The router connects to a smart switch via cat6 and then via internal cat6 through the walls to an upstairs socket. There are several sockets upstairs, so I've tried all of them and the problems are the same.
Could a switch cause the connection to drop (It's a netgear GS108T-V200, and I don't have a spare).
I'm going to factory reset the RT-AC68u and leave it alone and see if it can hold a connection to prove that it's not be updating the configuration that's killing the connection. I'll also isolate the switch to see if that's causing it.
Could these certificate errors cause the connection to drop? ( I get this in Firefox when I log into the router).
Other than that, I'm out of ideas. I don't know what else could be causing this.
