Hi folks,
I got a weird error I've never seen before, mybe you could help.
First of all, I flashed to the merlin-FW when I got the asus out of the box a few weeks ago
It definitely was a 374 build, not sure which revision, maybe 32.2 (?)
Everything worked fine...
Now, a few weeks later I want to fiddle with the config,
but now if I try to open the webinterface with http:/192.168.1.1 i got from chrome:
ERR_EMPTY_RESPONSE
webUI also does not open in IE, firefox from windows;
links, seamonkey from linux on different machine nor dolphin,android browser from mobile phone.
With a bit googeling I found the same error on the asus-forums,
there it was a problem when activating SSL for the webinterface. link
I never activated SSL, calling the page with https://192.168.1.1:8443 or std-port 443 doesn't work either.
ERR_CONNECTION_REFUSED
because it is not activated.
After several reboots the problem stays still the same.
I cannot access the router through webUI.
Thoug I can ping it, I can go to the webinterface of 192.168.0.1 which is my modem (accessible through the router), port forwarding works like I configured it, telnet and SSH access are still working.
But no WebUI.
I don't want to reset the router with the hard button on the back at this point, because I am not sure it will work after and I could restore my backup-configs?
Do you have any idea what this problem could be?
thanks a lot to the community, your're great!
best regards!
ERR_EMPTY_RESPONSE
But no WebUI.
best regards!
