I tried to install firmware 380.68 on RT-AC68R under 384-something. It failed to install directly at first so I loaded 378.55 first. It went well I was able to load into Web-GUI. Then I tried to load 380.68 and now router seems to be in the infinite loading loop.
1. All network LEDs are blinking once
2. USB 2,0 light is lit for about 8 seconds
3. USB light is gone, power LED is on for about a minute or two.
And it starts again
I tried to set it to recovery mode but I cannot.
Things I tried:
Hold reset while powering it on
Hold WPS while powering on
30-30-30 with reset
30-30-30 with WPS
Nothing breaks the cycle.
Any suggestions?
Thank you.
And it starts again
Things I tried:
30-30-30 with reset
30-30-30 with WPS
Any suggestions?
Thank you.
