Can't access admin after upgrade. 10.11.160.1 default router IP
REE
Just upgraded
RT-AC68U
Upgraded to RT-AC68U_384.7_2.zip
Rebooted after upgrade
Original settings wiped out.
Router IP identified as 10.11.160.1. Was previously set to 192.168.0.1.
Unable to access admin UI with http, https :8443, etc. or trying previous router IP.
Tried holding the reset button on the back and then rebooting
Able to connect to ASUS, ASUS_5G and via ethernet.
Appreciate any help!
From https://github.com/RMerl/asuswrt-merlin/wiki/FAQ
Q: How do I wipe my settings? Reset button does not work.
A: If the firmware fails to boot, then the reset button won't work. Turn the router off, press the WPS button. While keeping it pressed turn the router back on. Wait a few seconds, then release the WPS button. Settings will be back to factory defaults.
Keep persevering. By the way, what firmware did you upgrade from?
What router are you actually using?
Your previous posts refer to an RT-AC68A ( an Amazon special with cut down features) which you had problems flashing Merlin firmware to.
Just upgraded
RT-AC68U
Please check your ip again at http://whatsmyrouterip.com and see if it's correct
