Can't access DHCP Server config in 384.3
dth
I recently installed Merlin for first time on my AC2300. Version 384.3. As far as I can tell everything is working fine besides LAN/DHCP Server /Advanced_DHCP_Content.asp. When I link via the DHCP tab on LAN config page I redirect to the router login screen /Main_Login.asp. Any idea about how to fix this? I apologize if I've missed this discussion or instructions posted elsewhere, just started using Merlin.
Do a factory default settings reset on your ac3200 and also clear your browser cache. Everything will be fine.
You can also try the recently released 384.4 beta release.
