Can't access routers interface after a firmware install.
mm86
I installed some experimental firmware,
Internet works but i cannot access router interface though the browser.
here is my netsh dump:
popd
# End of Teredo configuration
# 6to4 Configuration
pushd interface 6to4
reset
set state state=disabled
popd
# End of 6to4 configuration
# Bridge configuration (not supported)
# End of Bridge configuration
# Wired LAN Configuration
pushd lan
popd
# End of Wired LAN Configuration.
Mobile Broadband configuration dump is not supported
# Health Registration Authority configuration
pushd nap hra
popd
# End of NAP HRA configuration
# Network Access Protection client configuration
pushd nap client
# Trusted server group configuration
reset trustedservergroup
# Cryptographic service provider (CSP) configuration
set csp name = "Microsoft RSA SChannel Cryptographic Provider" keylength = "2048
# Hash algorithm configuration
set hash oid = "1.3.14.3.2.29"
# Enforcement configuration
set enforcement id = "79617" admin = "disable" id = "79619" admin = "disable" id
= "79621" admin = "disable" id = "79623" admin = "disable"
# Tracing configuration
set tracing state = "disable" level = "basic"
# User interface configuration
reset userinterface
popd
# End of NAP client configuration
# Remote Access Configuration
pushd ras
set authmode mode = standard
delete authtype type = PAP
delete authtype type = MD5CHAP
delete authtype type = MSCHAPv2
delete authtype type = EAP
delete authtype type = CERT
add authtype type = MSCHAPv2
delete link type = SWC
delete link type = LCP
add link type = SWC
add link type = LCP
delete multilink type = MULTI
add multilink type = MULTI
set conf confstate = disabled
set type ipv4rtrtype = lananddd ipv6rtrtype = none rastype = ipv4
set wanports device = "WAN Miniport (SSTP)" rasinonly = disabled ddinout = disab
led ddoutonly = disabled maxports = 2
set wanports device = "WAN Miniport (IKEv2)" rasinonly = disabled ddinout = disa
bled ddoutonly = disabled maxports = 2
set wanports device = "WAN Miniport (L2TP)" rasinonly = disabled ddinout = disab
set wanports device = "WAN Miniport (PPTP)" rasinonly = disabled ddinout = disab
set wanports device = "WAN Miniport (PPPOE)" ddoutonly = disabled
set user name = Administrator dialin = policy cbpolicy = none
set user name = Guest dialin = policy cbpolicy = none
set user name = HomeGroupUser$ dialin = policy cbpolicy = none
set user name = MM dialin = policy cbpolicy = none
set ikev2connection idletimeout = 5 nwoutagetime = 30
set ikev2saexpiry saexpirytime = 480 sadatasizelimit = 100
popd
# End of Remote Access configuration.
# Remote Access Diagnostics Configuration
pushd ras diagnostics
set rastracing component = * state = disabled
set modemtracing state = disabled
set cmtracing state = disabled
set securityeventlog state = disabled
set loglevel events = warn
popd
# End of Remote Access Diagnostics Configuration.
# Remote Access IP Configuration
pushd ras ip
delete pool
set negotiation mode = allow
set access mode = all
set addrreq mode = deny
set broadcastnameresolution mode = enabled
set addrassign method = auto
set preferredadapter
popd
# End of Remote Access IP configuration.
# Remote Access IPv6 Configuration
pushd ras ipv6
set negotiation mode = deny
set routeradvertise mode = enabled
popd
# End of Remote Access IPv6 configuration.
# Remote Access AAAA Configuration
pushd ras aaaa
popd
# End of Remote Access AAAA configuration.
# WinHTTP Proxy Configuration
pushd winhttp
reset proxy
popd
# End of WinHTTP Proxy Configuration
C:\Windows\system32>route print
Interface List
12...00 ff 2f 43 7d 34 ......TAP-Windows Adapter V9
11...50 e5 49 c8 2d fc ......Realtek PCIe GBE Family Controller
1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.101 276
192.168.1.101 255.255.255.255 On-link 192.168.1.101 276
192.168.1.255 255.255.255.255 On-link 192.168.1.101 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.101 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.101 276
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
1 306 ff00::/8 On-link
Persistent Routes:
None
Interface List
IPv4 Route Table
Active Routes:
Persistent Routes:
None
IPv6 Route Table
Active Routes:
Persistent Routes:
None
You left out one critical bit of information: what's the router model?
