Can't access Wireless setting for 5G for slave on Repeater Mode (AC-68U)
What browser are you using? Did you try rebooting the device used to access the router?
Yes, reboot did not fix anything. Tried on both Chrome and IE.
Also, on the parent router the settings are accessible. Issue is just on the slave in the Repeater Mode.
You're actually not supposed to even be able to access that page. It's in repeater mode, which means you cannot modify those settings.
That's why the page isn't visible when you click on Wireless.
