cant connect netgear MBR624GU with
First attempt to connect it with encryption disabled. Either turn off MAC filtering or add the DS to the list. Make sure your router is not set to G-only mode. If it works with no encryption, you will have to settle with WEP for security since WPA/WPA2 is not supported.
