Can't create/rename folder on USB drive connected to router.
blueeon
So, I've had the RT-66NU for a few months now and I like it a lot. I've been using the AIDISK and FTP sharing options on it quite a bit, but recently, I can't create or rename folders via the web GUI in the router. The AI cloud app will play or read the files just fine and I can add files via windows explorer, but I can't create new folders or rename existing ones via the web interface. It will just hang on the processing screen. I also can't delete folders.
I have upgraded the firmware, reset to factory defaults, tried different usb drives, etc. As far as I can tell, each folder in the sda1 directory has read/write access.
Would anyone be able to understand why this is happening, especially since I hadn't changed any settings beforehand? Thanks for any help anyone may be able to give.
I thought about doing that. I know how to telnet into the router, but I'm not sure what commands I would use to create or rename a folder on the stick.
