I have about 40 LIFX bulbs and AiMesh (and HomeKit). @thobux would be interested to hear how you get on... (I used the suggested LIFX settings on 2.4Ghz only - and yeah WMM is Enabled)in the professional settings I don't get a 'Disable' function, only 'Enable'. LIFX says I need to dsiable it otherwise the connection to the lights are unstable.
Any idea, how to disable it? Thanks
thanks will try it this wayWMM can only be disabled if Wifi is set to Legacy mode.
I'm a bit annoyed how LIFX is handling this, I have no issues w/ TP-Link bulbs and switches. They explicitly told me to disable WMM. I'll report back here.I have about 40 LIFX bulbs and AiMesh (and HomeKit). @thobux would be interested to hear how you get on... (I used the suggested LIFX settings on 2.4Ghz only - and yeah WMM is Enabled)
Legacy, /out WMM cured my issues (w/ LIFX), and yes A…Fairness has been disabled (for the record - TP-Link bulbs work fine with a more modern setup though)WMM can only be disabled if Wifi is set to Legacy mode.
Then the manufacturer needs to fix that. They are basically forcing you to run a router in 802.11g mode to accommodate their lights.
I suspect the LIFX bulbs are running the Espressif ESP8266 microcontroller - there's versions of the libs that have connectivity issues like what's reported by OP... As luck would have it, there are fixes available, and depending on the firmware that LIFX is using, it might be something OTA updatable...
yes. that's what they said.I am running a ton of LIFX bulbs (newer as they are RGB) without WMM disabled.
@thobux did LIFX support specifically tell you to turn it off or were you going by the instructions?![]()
I'm using bulbs and a beam. Recently I'm having troubles with the beam. I need to un/plug it from mains every now and then to connect it to the wifi and make it visible again.@thobuxAlso what type of LIFX bulbs are you using, and what specific problems are you seeing... if they remain visible to the LIFX app (as mine do) then that's good as far as WiFi/LIFX is concerned. I do have some AiMesh & HomeKit issues but those I believe are separate routing issues.
Welcome To SNBForums
