SoftDux-Rudi
I'm trying to disconnect some iSCSI targets, but can't seem to.
I need to disconnect all 4 of these
The target is still there, even though I tell it to disconnect.
I can't delete it either:
Restarting iscsi gives some odd errors:
Interestingly, the targets which iscsi reports as not existing, does exist:
Is there any other way to force these disconnects, and re-connect them?
[root@localhost ~]# iscsiadm -m session
tcp: [1] 192.168.2.202:3260,1 iqn.2011.01.22.freenas.nvr:500gb
tcp: [3] 192.168.2.200:3260,1 iqn.2011-2.za.co.securehosting:RAID.thin3.vg0.1tba
tcp: [4] 192.168.2.202:3260,1 iqn.2011.01.22.freenas.nvr:extent0
tcp: [5] 192.168.2.200:3260,1
iqn.2011-2.za.co.securehosting:RAID.iscsi0.vg0.500gb
[root@localhost ~]# iscsiadm -m node -T 192.168.2.200:3260,1
iqn.2011-2.za.co.securehosting:RAID.iscsi0.vg0.500gb -p 196.34.136.200
--logout
[root@localhost ~]# iscsiadm -m node --op delete --targetname
iscsiadm: no records found!
[root@localhost ~]# /etc/init.d/iscsi restart
Logging out of session [sid: 1, target:
iqn.2011.01.22.freenas.nvr:500gb, portal: 192.168.2.202,3260]
Logging out of session [sid: 3, target:
iqn.2011-2.za.co.securehosting:RAID.thin3.vg0.1tba, portal:
192.168.2.200,3260]
Logging out of session [sid: 4, target:
iqn.2011.01.22.freenas.nvr:extent0, portal: 192.168.2.202,3260]
Logging out of session [sid: 5, target:
iqn.2011-2.za.co.securehosting:RAID.iscsi0.vg0.500gb, portal:
192.168.2.200,3260]
Logout of [sid: 1, target: iqn.2011.01.22.freenas.nvr:500gb, portal:
192.168.2.202,3260]: successful
Logout of [sid: 3, target:
192.168.2.200,3260]: successful
Logout of [sid: 4, target: iqn.2011.01.22.freenas.nvr:extent0, portal:
Logout of [sid: 5, target:
Stopping iSCSI daemon:
iscsid dead but pid file exists [ OK ]
Starting iSCSI daemon: [ OK ]
[ OK ]
Setting up iSCSI targets: Logging in to [iface: default, target:
iqn.2011-2.za.co.securehosting:RAID.thin1.vg0.2tb, portal:
192.168.2.200,3260]
192.168.2.200,3260]
192.168.2.200,3260]
iqn.2011-2.za.co.securehosting:RAID.thin2.vg0.1tb, portal:
192.168.2.200,3260]
Login to [iface: default, target: iqn.2011.01.22.freenas.nvr:500gb,
portal: 192.168.2.202,3260]: successful
iscsiadm: Could not login to [iface: default, target:
iscsiadm: initiator reported error (19 - encountered non-retryable
iSCSI login failure)
Login to [iface: default, target: iqn.2011.01.22.freenas.nvr:extent0,
iscsiadm: Could not log into all portals. Err 19.
[root@localhost ~]# iscsiadm -m discovery -t sendtargets -p 192.168.2.200
192.168.2.200:3260,1 iqn.2011-2.za.co.securehosting:RAID.thin1.vg0.2tb
192.168.2.200:3260,1 iqn.2011-2.za.co.securehosting:RAID.iscsi0.vg0.500gb
192.168.2.200:3260,1 iqn.2011-2.za.co.securehosting:RAID.thin2.vg0.1tb
The machine runs on CentOS 5.5 x64 + XEN:
[root@localhost ~]# cat /etc/redhat-release
CentOS release 5.5 (Final)
[root@localhost ~]# uname -a
Linux localhost.localdomain 2.6.18-194.el5xen #1 SMP Fri Apr 2
15:34:40 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost ~]#
