Can't execute scripts without sh
Works fine here.
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Fri Jul 17 03:17:04 UTC 2015
admin@rt-ac68u:/tmp/home/root# echo "echo hi" >t.sh
admin@rt-ac68u:/tmp/home/root# chmod +x t.sh
admin@rt-ac68u:/tmp/home/root# ./t.sh
hi
Works fine here.
hi
I need feedback if you restore to factory settings and then install optware from that guide.
It may be more productive to have a few people having the issue represent themselves so a root cause can be determined. If they need to prefix scripts by sh, its likely an environment issue or a busybox problem or config problem deployed as part of optware.
Hi, i have same problem:
admin@RT-AC68U-7538:/tmp/home/root# sh /opt/etc/init.d/S95transmission stop
: not foundit.d/S95transmission: line 2:
: not foundit.d/S95transmission: line 7:
: not foundit.d/S95transmission: line 10:
: not foundit.d/S95transmission: line 13:
: not foundit.d/S95transmission: line 17:
: not foundit.d/S95transmission: line 21:
: not foundit.d/S95transmission: line 23: {
/opt/etc/init.d/S95transmission: line 36: syntax error: unexpected word (expecting "do")
admin@RT-AC68U-7538:/tmp/home/root# echo $PATH
/bin:/usr/bin:/sbin:/usr/sbin:/home/admin:/mmc/sbin:/mmc/bin:/mmc/usr/sbin:/mmc/usr/bin:/opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin
admin@RT-AC68U-7538:/tmp/home/root# echo $SHELL
/bin/sh
admin@RT-AC68U-7538:/tmp/home/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=127760k,nr_inodes=31940,mode=755)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
/dev/sda1 on /tmp/mnt/OPTWARE type ext2 (rw,nodev,relatime,errors=continue,user_xattr)
/dev/sdb1 on /tmp/mnt/1TB_Data type ext3 (rw,nodev,relatime,errors=continue,user_xattr,barrier=0,data=ordered)
I found the culprit, I have to add path to non working scripts
PATH=/opt/sbin:/opt/bin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
/bin/sh
rm /opt/etc/init.d/S95transmission
wget -c -O /opt/etc/init.d/S95transmission http://goo.gl/aw99qs
chmod a+rx /opt/etc/init.d/S95transmission
/opt/etc/init.d/S95transmission start
