Cant flash Merlin AC68U
psychohh
Hello,
i have buy a AC68U and i can no flash Merlin to the Router.
The Message it will come is:
Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again.
I have reset and a 30-30-30 reset.
I can flash the original ASUS FW but not Merlin FW.
Product ID DSL-AC68U
DSL Firmware Version 1.0.3.2
DSL Driver Version FwVer:5.5.1.135_A_A60901 HwVer:T14.F7_0.2
I have download multiple RT-AC68U_380.57_0.trx with chrome, safari, firefox and check hash. Its okay.
What can i do?
Thanks a lot
Hello,
What can i do?
Thanks a lot
Your DSL version of ASUS routers is not supported.
Here is a list of the non-DSL ASUS routers that can be flashed with RMerlin's Firmware:
http://asuswrt.lostrealm.ca/about
Are you trying to install the newest version, 380.57? There have been some problems with it, and to avoid that, I'd suggest you try to install 378.55 or 378.56_2, firstly to avoid the problems of the new version, and, secondly, to see if the problem extends beyond the version you tried.
I don't think it applies to you, because your firmware appears to be fairly up to date, but I was reminded of this posting:
http://www.snbforums.com/threads/upgrade-to-378-56_2-from-376-47_0.29173/#post-224758
Nevertheless, worth a read and storing in the dark corners of one's memory (as are most of this forum's postings).
EDIT: thanks Martineau. In my subconscious, when I saw DSL, something didn't sound right, but it never made its way to the conscious (or in my case, semi-conscious) part of the brain.
Ah shirt.
I habe a DSL-AC68U and not a RT-AC68U.
wtf..
I did not even know that there is a version with and without modem.
Can i deactive the dsl and flash then Merlin?
Ah shirt.
wtf..
Not possible.
