cant generate certs
sabot105mm
im really lost, i have no idea why easy-rsa is having such hissy fit. i followed the openvpn howto info to the letter but no dice. my computer is running win7 64bit with the latest installation of openvpn
C:\Users\Gary>cd \Program Files\OpenVPN\easy-rsa
C:\Program Files\OpenVPN\easy-rsa>init-config
C:\Program Files\OpenVPN\easy-rsa>copy vars.bat.sample vars.bat
The system cannot find the file specified.
C:\Program Files\OpenVPN\easy-rsa>vars
C:\Program Files\OpenVPN\easy-rsa>clean-all
Access is denied.
The system cannot find the path specified.
0 file(s) copied.
0 file(s) copied.
C:\Program Files\OpenVPN\easy-rsa>build-ca
WARNING: can't open config file: /etc/ssl/openssl.cnf
Loading 'screen' into random state - done
Generating a 1024 bit RSA private key
unable to write 'random state'
writing new private key to 'keys\ca.key'
keys\ca.key: No such file or directory
4032:error:02001003:system library:fopen:No such process:bss_file.c:39
eys\ca.key','wb')
4032:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:400:
A WireGuard Server is running but clients cant connect VPN 2
