TheLyppardMan
I've used ledscontrol before and not had any problems, but now I can't get it to install. It adds an entry to the services-start file, but that's about it. If I check the amtm menu after going through the setup procedure, it's not listed as an installed script and if I choose the "i" option, ledscontrol still appears as if I hadn't installed it. Any ideas how to correct this?
