can't recover LVM volume: Please specify a *single* volume group to restore
SoftDux-Rudi
Hi everyone,
I'm trying to recover a deleted LVM volume but can't see to get the
syntax right.
Running the following command gives me a list of backed up LVM volumes:
root@usaxen02:[~]$ vgcfgrestore -l fluidVG_125094317679
------- snip ---------
File: /etc/lvm/archive/fluidVG_125094317679_00126-1479850541.vg
VG name: fluidVG_125094317679
Description: Created *before* executing 'lvremove
/dev/fluidVG_125094317679/mars.x.com_root_125152080771'
Backup Time: Tue Aug 2 17:40:44 2011
File: /etc/lvm/backup/fluidVG_125094317679
Description: Created *after* executing 'lvremove
So I want to recover mars.x.com_root_125152080771 and issue the
following command:
root@usaxen02:[~]$ vgcfgrestore -f fluidVG_125094317679
fluidVG_125094317679: stat failed: No such file or directory
Couldn't read volume group metadata.
Restore failed.
Please specify a *single* volume group to restore.
root@usaxen02:[~]$ vgcfgrestore -f mars.x.com_root_125152080771
All different attempts, which apparently should work according to some
google search results I've found but doesn't.
Another attempt:
root@usaxen02:[~]$ vgcfgrestore -vvt
Test mode: Metadata will NOT be updated.
Setting global/locking_type to 1
global/wait_for_locks not found in config: defaulting to 1
File-based locking selected.
Setting global/locking_dir to /var/lock/lvm
Test mode: Wiping internal cache
Wiping internal VG cache
Does anyone know what the correct syntax should be on CentOS 5.5?
