Hey everybody,
I'm using Asus RT-AC68U in router mode with the latest Merlin 3.0.0.4.374.39 build.
I'm trying to set up an OpenVpn connection for certain WiFi SSIDs as described here:
https://github.com/RMerl/asuswrt-merlin/wiki/How-to-setup-SSID-for-VPN-and-SSID-for-Regular-ISP-using-OpenVPN.
The problem is:
The guest networks don't work. I don't see the SSIDs. Trying to connect to the guest networks manualy (hidden SSIDs) doesn't work.
In the web UI everything seems just right.
Trying to unhide the Guest Networks using:
Doesn't work either. Found in this Post.
The administration protocol for WiFi doesn't show the guest networks.
Deactivating/ activating guest networks doesn't work.
Rebooting the router doesn't work.
OpenVpn is running perfectly.
So my problem is the "simple" step of setting up guest networks...
I'm lost
Any help would be really appreciated!
Cheers,
BuzzDee
The problem is:
nvram set wl0.1_closed=0
nvram commit
nvram set wl1.1_closed=0
nvram commit
I'm lost
Cheers,
BuzzDee
