jsmiddleton4
Thought I'd try tonight. I get to the "Process starting" screen/window and then nothing. Just sits there.
Didn't damage the router, brick it, etc. Just did nothing.
This might be by design. Just thought I'd mention it.
I'm not sure why it wouldn't let you update the firmware from an internal sdhc card.
I've never tried the USB attached hard drive.
Could be the process only works if you use a LAN attached device for the location of the firmware.
