CAT6, CAT6A cable recommendation
kisseri93
Hi everyone!
I need 30 meters of CAT6 or CAT6A cable. I would run the cable through a conduit in the wall from the modem to the router. Is there a specific brand that you would recommend? Or perhaps a specific product?
I live in Europe, Hungary. EU orders are fine!
Thank you!
Get CAT6A. Monoprice cables are pretty good and not expensive. They ship worldwide
Leave a pull chord in the conduit when you pull the cable through.
Some people would suggest pulling 2 cables instead of 1 as the cost of cable is cheap, but you might have to increase the conduit diameter.
Don't buy from no-name companies on Amazon. Purchase from a reputable network cabling company (then "brand" doesn't really matter).
Are you going to cut the cable to the exact length and terminate it yourself, or are you looking for a pre-made 30m patch cable? Many of the quality pre-made Cat6 cables only go up to 20m, so 30m might be a special order.
To add, are there any bends in the run? CAT6 has a tighter bend radius than CAT6a.
Monoprice UTP bulk cable doubled or tripled in price in the past few months. I think the price of copper is up? Or getting ready for tariffs? A LOT more expensive.
Good brands in USA: Belden, Mohawk, West Penn, Berk-Tek, Superior Essex--in Europe, maybe Siemon? (Not familiar with what is available there.)
Of course look for pure copper cable, NOT CCA, "copper clad aluminum", which by definition does not meet spec.
Can also use "long radius" 90 degree elbows, or 2 x 45 degree elbows, or a large pull box to make turns.
Too small of a radius distorts the shielding and can cause it to fracture.
I don't think OP needs shielded cable, unless their home is very unusual?
Stay away from CCA (copper clad aluminum wire) types.
I personally like foam core CMX jacket type because its hard to kink and easy to pull in conduit.
