SkOrPn
Hey guys, sorry for asking this noob question, but suddenly I am thinking I made a mistake with my home networks cabling a few years back.
Recently I located EVERY CAT5 cable I could find and tossed them away and decided that for any patch cable over say 3 feet I would use 24AWG CAT6 stranded, and also for anything coming off of Gigabit enabled ports (so almost every patch cable). Then for the lone 10/100 switch (2 foot from the router) I would continue to use good self-built CAT5e cables so long I kept the runs short. For the service line from the router to that switch, I went a head and used CAT6 (about 3') though, because it felt right. I want my home networks cabling to be "ideal".
Here is the worry I suddenly have. Years ago I replaced our 1980's long 100' (I think 4 conductor CAT3? analog phone wire) run from the VDSL+ access panel to the modem+Router location (C1000A + RT-AC66U_B1). I used CAT6 stranded because it was what I had plenty of and thought it would be perfect (not counting 23AWG) for the 100 foot run. Then I used this same CAT6 stranded for the 2nd longest run from the router to the 8-port Gigabit switch, about 75 foot away. I am really good at making cables, but have not been so good at studying exactly how they should be deployed (I'm improving). I believe my network would get a solid B but that isn't good enough in my mind. I want it to be A+ and a really good Network engineer would have no possible improvement tip to give me, lol.
Anyway, recently I read a Networking article that recommended to never use more than 20 feet per patch of CAT6 stranded especially if its 24AWG or smaller in size? This has really bothered me because the main internet access run and main gigabit run to the switch are both well over 20 feet. I guess I wasn't paying much attention, but I believe I should have used 23AWG solid CAT6 for the internet service AND for that 75' Gigabit switch run, since both are non-patch stationary and under the home. (???)
So was that article correct that I should NOT use CAT6 24AWG stranded for anything longer than 20 feet? Would it be worth replacing at least those two runs with 23AWG solid? I mean its not that expensive, but it is under the House and a real pain to crawl. If I would see ZERO difference than I wont bother, but if there is even 1% difference, OR a matter of proper quality pride, than I would want to take care of it. I don't like doing things just a.o.k, I like to do them A+ so I don't have to worry about it for at least another decade.
Am I over thinking, or did I do it wrong?
Best Regards
Rod
Best Regards
Rod
